I hope you are well.
I wonder if someone can help me with something?
I have a Ford Econoline with an LPG conversion. It is a first generation system which runs a V8 engine. It has three tanks, two of which supply the engine with LPG, the third was connected to a now defunct domestic LPG system. I want to 'plumb' the third tank into the fuel system.
My questions relate to:
I was going to use a one way t-valve to connect the system after the previous t-connection between the first and second tanks. I understand there is some debate about expansion of LPG in the pipes, so is that the best thing to do?
I also wanted to check if the solenoid and manual valves will stop the gas from being vented when the fuel pipes are opened?
Finally,
Thanks in advance
Jamie
