raeturbo
- New member
#1
Post
by raeturbo » Tue Dec 05, 2017 11:48 am
Hi all, it's been a while since I've been here as my Astra is still running fine
I have just bought a vauxhall omega 3.2 v6 with a Landirezo gas kit fitted
I need the software and lead (maybe other things I don't know) as I need to
Get into the System to alter the time the gas will come on etc.
Can anyone help me please? Thanks Rae.
raeturbo on Tue Dec 05, 2017 4:50 pm, edited 1 time in total.
raeturbo
- New member
#2
Post
by raeturbo » Tue Dec 05, 2017 4:49 pm
Sorry should, be Landi Renzo
- Intermediate Member
#3
Post
by Brian_H » Tue Dec 05, 2017 8:50 pm
You can pickup the lead either from WTV (
http://lpg-kits.com/) or lpg shop (you need 2 leads in their case,
http://www.lpgshop.co.uk/base-ccy-usb-l ... to-milano/ and
http://www.lpgshop.co.uk/diagnostic-int ... ndi-renzo/). Other places may have it as well, the WTV one comes with the software, not sure on any others.
You'd best check which ecu it is first though, to be sure you can get the software.
The older ones (Omegas for example) won't let you set a switchover below 40 degrees, and some versions of the software will only let you set switchover at 1600rpm (the older version of the same software will let you set it lower though). Also if its cold starting i found you couldn't get it to switch over until it had been running approx a minute on petrol. Warm restarts tended to be a lot quicker.
raeturbo
- New member
#4
Post
by raeturbo » Tue Dec 05, 2017 11:20 pm
Thankyou Brian.
raeturbo
- New member
#5
Post
by raeturbo » Thu May 21, 2020 12:58 pm
Cars playing up again think I need some landirenzo black, Injectors... anybody have any for sale?
#6
Post
by Brian_H » Thu May 21, 2020 7:20 pm
Tinley have them, but they aren't cheap >
https://tinleytech.co.uk/shop/lpg-parts ... ueblack-2/
They are usually referred to as MED injectors.
It may be worth a try with some IC12 or similar injector cleaner. Not sure if you can use any other injectors on the Landi-Renzo (is it Omegas you've got?) I remember from mine that there wasn't a lot of options there. If you could find alternative injectors they may well be better (and cheaper). Be aware though that the Med rail has both the pressure sensor intergrated into it, and 14mm pipe which is unusual. You could get round the pipe fairly easily (use a replaceable filter with 14mm inlet and 12mm outlet to bridge the size gap).
Whats it doing to make you think the injectors are at fault?
raeturbo
- New member
#7
Post
by raeturbo » Tue Jun 02, 2020 1:16 am
Thank you Brian, they are very noisy I took the gas pipe to the injectors off and sprayed some brake cleaner it and run the engine then I done the same with Wd40 it’s a bit better now but I think they’re worn out as they’ve done over 120,000 miles Yes they are the round Omega’s black
#8
Post
by Brian_H » Tue Jun 02, 2020 10:03 pm
Those injectors are noisy as they get old - mine were very noisy. They aren't known for being particually good either. Not sure if a better option is available thats compatible with your ECU, though do you have the pressure sensor mounted in the end of the injector rail on your setup?
raeturbo
- New member
#9
Post
by raeturbo » Sun Jan 24, 2021 12:13 am
Hi Brian, yes the pressure sensor is mounted on the rail only just saw your reply
I couldn’t get back on the site for ages password etc
I’m looking for a temprature sensor now for it but can only find them in Poland and I’m not sure the exact 0ne I need it’s a 210hp reducer LSI
#10
Post
by Brian_H » Sun Jan 24, 2021 1:18 am
Temp sensor for the coolant or the gas temp sensor? If its the coolant one, then as long as its electrically the same, or even one you can select from the options in the software, then you should be ok. Mine had an inline one in the pipework next to the reducer. Might be easier/cheaper to go with one like that, but need to check which one would work with the ECU.
Tinley might be able to advise if your not sure.
The username forgotton Problem has come up a few times, if you get really stuck it may be easier to create a new account and drop a message in asking one of us to send a PM to your old account. That should generate an email which then let's you use the forgot password link. There are other things that can be done, but that's the simplest way I've found so far.
#11
Post
by Brian_H » Sun Jan 24, 2021 5:55 pm
This might be the right sensor? Check with the supplier before you order though, might be worth checking the size of the hoses running to the vapouriser as well (16mm is a usual size, you'd probabbly get a 15mm one to fit and seal with suitable clips though).
https://tinleytech.co.uk/shop/lpg-parts ... m-in-line/
The manual for Omegas (Assuming you have that version, as you've not said otherwise) lists a 4.7ohm sensor. With that a supplier should be able to suggest something suitable. Mine wasn't using the square type reducer you have, and had similar to the post I've linked to above. If you want a copy of the manual find the software and its with that (linked from Tinley tech website - on the projekt-tech list) or drop me a pm with your email address and I will email it to you.
If it isn't Omegas you have, it would be helpful if you could identify it.
