Elgrand 51 series 2.5 and 3.5 for LPG
david_1972
#1 Post by david_1972 » Thu Jan 07, 2021 7:51 pm
Hi all,
Lost my login details so have re-registered :oops:
Anyway, my question is this - is there any difference in suitability of LPG converting the 2.5v6 compared to the 3.5v6 Elgrand please?
Thank you
David
Re: Elgrand 51 series 2.5 and 3.5 for LPG
#2 Post by Brian_H » Thu Jan 07, 2021 8:15 pm
Hi David
Simon (LPGC) on here is bound to have some input on the Elgrand, as he has a couple of them and is an installer as well.
On the lost login, if you goto the login page there should be a forgotton password link - or use this link
ucp.php?mode=sendpassword
If you can remember your email address, then that should allow you to reset the password. If you can't remember your email address but can remember the username, post a message here and we will see if it can be sorted out (provided you still have access to whatever email address it was registered to this should be fairly simple).
david_1972
#3 Post by david_1972 » Thu Jan 07, 2021 8:26 pm
Thanks Brian. I tried both of my email addresses and they didn't seem to be recognised. My old username was david1972.
It's not a problem, but thank you for offering to assist.
#4 Post by Brian_H » Thu Jan 07, 2021 8:33 pm
I've sent you a pm under that account so hopefully you will get an email notification for it. That may help!
david1972
#5 Post by david1972 » Thu Jan 07, 2021 8:39 pm
Thank you Brian - back in with my old account :)
#6 Post by LPGC » Fri Jan 08, 2021 5:32 pm
Like Brian said, I've converted a lot of Elgrands to LPG and I run 2 Elgrands myself.
The 2.5 and 3.5 in the E51 and the older 3.3 in the E50 are all equally well suited to running on LPG. Of course injector nozzle size, pressure and calibration settings are different for the different sized engines.
david_1972
#7 Post by david_1972 » Fri Jan 08, 2021 8:03 pm
Thank you Simon
#8 Post by LPGC » Sat Jan 09, 2021 12:16 am
Thank you Simon
I sent you a PM earlier.
david_1972
#9 Post by david_1972 » Sat Jan 09, 2021 11:51 am
Thank you Simon
To which username Simon - I can't get in to my david1972 account again for some reason. Sorry
david1972
#10 Post by david1972 » Sat Jan 09, 2021 12:05 pm
Thank you Simon
Thank you - I've got back in to my primary account now and have replied to you :D
