Engineering company suggestions for hard valves/seats
Re: Engineering company suggestions for hard valves/seats
#41 Post by Pinger » Sat Jan 09, 2021 2:29 pm
desauld wrote:
Fri Jan 08, 2021 9:01 pm
So that's where I'm at. I have had very bad luck with easy outs in the past so I don't want to break one in the crank here. But maybe I'm into that level now. Really I need an engine...
Very bad luck.
I suspect you are about right re easy outs and at 'that level now'.
Two things I'd try before going in with the easy outs. One, try hammering on the end of what's left of the bolt to 'shock' the Loctite free. Two, try and find out what best dissolves Loctite. If nothing, then a good penetrant (not WD40) and let it soak. If there was a way of pressuring it in all the better (all I can think of is (assuming the bolt is in a 'blind' hole) drill your crank bolt right through, drill your M12 bolt right through, tap it for a a grease nipple , fit the bolt and squirt solvent/penetrant through the hole before fitting the grease nipple, then pressurise with a grease gun and hope the penetrant is forced between the big bolt's threads and the crank's. Use a tube and hammer (when pressurised) to further add shock. Maybe, just maybe, it might break its hold and allow an easy out to do the rest).
desauld
#42 Post by desauld » Sat Jan 09, 2021 4:25 pm
Very bad luck.
Thanks for the support guys and some good suggestions there. The internet says, so how could it be wrong, that thread locker hates acetone and chloroform. I unfortunately am right out of the latter, 🤣 bit have some acetone in the cavity in the crank now behind an M12 bolt to hopefully spread it under pressure around the M16 remains, if that makes sense. I will go back at it tomorrow with propane, a tig torch with way too much tungsten stickout and heat it up as much as I dare. Locktight says over 260 deg c will soften it, so let's see...
#43 Post by LPGC » Sat Jan 09, 2021 5:42 pm
Very bad luck with it snapping and attempts to get it out so far, wish you better luck on your next attempt.
#44 Post by Gilbertd » Sat Jan 09, 2021 7:46 pm
Not easy to get hold of but if you can find a LH thread tap and bolt, that might be better than an Easy out.
desauld
#45 Post by desauld » Sat Jan 09, 2021 8:08 pm
I'm actually thinking of mashing in a no 12 or 14 12 point spline bit. I have had some luck doing this in the past on exhaust and turbo studs.
#46 Post by Pinger » Sun Jan 10, 2021 10:54 am
Don't forget shocking it from the front. Hammering on it will push it away from the direction it was pulled when it was tightened.
Good info on the acetone - easily found in nail varnish remover I think.
Hang in there - you can win this one!
desauld
#47 Post by desauld » Sun Jan 10, 2021 7:34 pm
The fecker is out!
Left it soaking in acetone over night, then heated a M12 bolt up which I had threaded into it so it was red hot right up to the nose of the crank for 10 mins. Then mashed in the spline drive, tightened it a bit first, could feel it start to move, then backed it out. So back to the rest of the job.
I have one head off, and the other almost ready to come off. Not difficult, just plenty to do. Everything looks good. Apart from the general mess. I filled all the ports with thinners and there is very slight weeping past some intake valves, mainly the one with low compression. It's only very little to be fair and a lapping in would allow it to seal.
desauld
#48 Post by desauld » Sun Jan 10, 2021 7:35 pm
Some pics
desauld
#49 Post by desauld » Sun Jan 10, 2021 7:38 pm
Interestingly, the tappets are one piece, and don't have the top part which removes, no wonder I couldn't get it to split! So to adjust the clearance on this engine you have to remove the cams. That are also smaller than the other spares I picked up. Odd.
#50 Post by Pinger » Mon Jan 11, 2021 9:46 am
The fecker is out!
Result! Well done that man!
Re one piece tappets - that makes for a very high maintenance engine. On a par with a motorcycle engine.
I think it was yourself that mentioned (it must have been on this thread even if not you) that solid tappets were a Jaguar preference. If Ford were behind it then coming from their background of pushrod V8s with hydraulic tappets, that's a hell of a jump re maintenance requirements.
#51 Post by Brian_H » Mon Jan 11, 2021 9:57 am
Some Ford engines use the same arrangement for the tappets as that shown. The Duratec ones I think are where that started. The later Zetecs were shimmed. Though those all 4 pot engines obviously.
Well done on getting it out though, acetone a good thing to know.
#52 Post by Gilbertd » Mon Jan 11, 2021 10:54 am
Or one where they don't expect you to do any maintenance, just throw it away when it starts to wear out.
Re Acetone, I read somewhere that a 50:50 mix of Acetone and ATF works better than Plus Gas on seized bolts and mentioned this to someone I know who had an engine that had one cylinder open to atmosphere for a number of years and the piston rings had rusted to the bore on one pot. He misheard me and missed the ATF so filled the pot with neat nail varnish remover. After soaking for two days, he was able to turn the engine over!
#53 Post by Pinger » Mon Jan 11, 2021 12:44 pm
Not sure is there's a technical reason that stops a hyd tappet being used between a cam lobe and a valve on DOHC valve trains other than adding a lot of height but I can't think of an engine configured so.
Usually rocker arms are employed with the hyd tappet being a pivot point at their ends. But there are myriad factors an engineer considers when selecting valve train configurations. Ease of production assembly (of a built up head) being one where the head bolts must be accessible. Increasingly, overall height for reasons of pedestrian impact protection is a priority - the reason Mercedes moved their cam chains to the rear of the engine. There's a minimum cam chain sprocket diameter dictated by the drive one which in turn is determined by the crank diameter. Easily circumvented on a bike engine where no drives are required at that end of the engine. Not so much when you want to hang a big torsional vibration damper and myriad accessory drives on the nose of your crank.
Yep, especially as in nail varnish remover it's easily obtained.
#54 Post by Pinger » Mon Jan 11, 2021 12:53 pm
]Or one where they don't expect you to do any maintenance, just throw it away when it starts to wear out.
In fairness to solid tappets, they tend not to need adjustment - if the valves are made of decent material that is....
Our 'built in obsolescence' these days seems to be electronics. £1700 for an ABS/ESP ECU has effectively written off my smart. An otherwise good and useful little car - infinitely better than taking a bus ride in these Covid times.
I've heard some swear by ATF and diesel mixed. It is said that ATF has high detergency but I've not seen evidence - or need. Auto trans don't see dirt like an engine does and a good oil shouldn't be carbonising.
mgrover
#55 Post by mgrover » Sat Jan 16, 2021 4:28 pm
ahh i had mine done by mike at autogas. still driving me up the wall with lean trims.
