#24
Post
by LPGC » Mon Mar 30, 2020 2:28 pm
Whether or not they cause a vacuum/petrol sealing problem, fuel spray patter problem, etc, will depend on the engine in question.
On some engines they're not great regards correct point of LPG injection either. They're a tube wide enough for the petrol injector to mount on top of with a 'watering can' type spout coming off the side which the LPG pipe (from LPG injector) connects to - so the LPG doesn't squirt directly into airflow in the manifold port runner, instead it squirts through the spout bit into the wide bit which is spaced away from the inlet runner... which usually won't be as ideal as having LPG enter the port directly from a narrow(er) nozzle into airflow in the port.
Regards 'disturbing stuff', again it depends on the engine is question. The bottom of the 'watering cans' have to seal as well in the manifold as the petrol injectors did, the petrol injectors have to seal in the top of the watering cans as well as they sealed in the manifold. You want the sandwich setup (watering can, injector, fuel rail) with the increased height and with the spacers that will need to be used to secure the fuel rail at it's new height onto the engine's original fuel rail mounting points, to be as rigid/secure as it was originally. Hopefully the bits supplied will achieve this on the engine in question, speaking from experience sometimes the installer has to modify/fabricate bits to ensure this because the 'watering can' bits are not engine specific, it can be surprising how much rigidity/security is lost when the fuel rail is remotely mounted on extensions rather than being attached directly to original securing points.
On a V6 if the fuel rail is solid and wraps around the engine, if petrol injectors are sloped toward the centre line of the engine then spacing petrol injectors away from the manifold can mean the fuel rail needs to be made longer. On some inline engines fitting spacers can mean engine trim covers won't refit.
Most pros don't use them, they might have tried them at some point and had some good results on some engines but poor results on other engines... this combined with increased costs and the extra messing about fitting them make them a bad bet from the outset. All considered if it seems difficult to fit LPG spuds in the correct place it's usually a better idea to fit straws. Then again the idea of drilling a manifold to fit spuds or straws won't be a big deal to an installer but might seem a bigger deal to an amateur.
LPGC on Mon Mar 30, 2020 3:10 pm, edited 2 times in total.
