LPGC wrote:Easy to change on that motor and could buy 4 sets of nickle plugs for same cost...tom-madbiker wrote:Rover 25 1600 the iridium tipped ones last a good while but they are a Tenner
each
Point here easy to understand and similarly applying to long lived tyres - Good that you don't have to change them so often, unless some other problem occurs such as punctures (particularly in tyre sidewalls) or kerb damage (case of some drivers). I prefer to change plugs during servicing anyway, less chance of them being stuck when it comes to changing, gives opportunity to check if cam cover gaskets are leaking oil into plug chambers.
Aaaaaahhh, that would be the K-series then. A tenner a plug is painful, i can buy a set of 6 NGK Copper Core jobbies for my Rover on ebay for a tenner. However, if i decide to go for something a bit more exotic then it will cost obviously cost me more.
Have to agree with Simon though, they're dead easy to change and you could buy 4 times as many sets for the same money of less exotic plugs that still do the job. Possibly they'd do the job better as they would be "fresher" - maybe something to think on? That was the whole point of me asking the question in fact for this thread.
I suppose in many ways i have my answer now and it is an answer of many ways too - basically i'll try the standard plugs and see how it goes. I often manage to blag trade price from my local auto factors especially if i buy plugs for both Rovers at the same time - must check to see what the Jeep uses! Might get even more discount!
