The Temptress
Re: The Temptress
#141 Post by Gilbertd » Mon Jul 19, 2021 9:44 pm
Not that I know of. My everyday car has a Leo (in a box marked as a Bigas Pegaso) while the spare car has a Millennium and once past the initial splash screen the software is identical. If you save the settings it gives a file but with a different file extension (.leo and .mil or something like that), changing the file extension will allow you to load a saved settings file from a Leo to a Millenium and vice versa.
What are the manifold stubs for?
robertXX
Re: The Temptress
#142 Post by robertXX » Tue Jul 20, 2021 8:09 am
thank you gilbert , in that case ill use the leo , i prefer the name :)
the stubs are so that, if i choose to go megasquirt in future , like the astra and Medusa , i don't have to fit them then .
robertXX
Re: The Temptress
#143 Post by robertXX » Fri Jul 30, 2021 8:59 am
Re: The Temptress
#144 Post by Brian_H » Fri Jul 30, 2021 10:41 pm
Certainly looks like your getting there with it, definitely alive now!
jonathan_d
Re: The Temptress
#145 Post by jonathan_d » Fri Jul 30, 2021 11:04 pm
You’re doing great work, sounds tremendous. I’m trying to identify the grumbling noise but struggling, odd the way it comes and goes. Have you got the auxiliary belt on? I’m wondering if it’s something daft like waterpump bearing
Saab 9-5 Aero estate
Saab 9-3 Convertible
Nissan X-Trail
All on LPG
robertXX
Re: The Temptress
#146 Post by robertXX » Sat Jul 31, 2021 8:27 pm
Thanks jonathan ,i have got the belt on and the dynamo ,and water pump, working (although no charge ) , that will be easy to take off and see if it's that , i am tending towards the cam chain though .
Thanks Brian , it's a bit responsive :)
robertXX
Re: The Temptress
#147 Post by robertXX » Sat Oct 16, 2021 8:39 pm
well the noise WAS the camchain , and a quick loosen and re adjust made it quiet
.however a new problem has occurred .when trying to start the car, it will only start if i turn the gas on then off , and when it catches turn it on . this makes me think the R90 is leaking .. if that's so, are there any favourite leak points to concentrate on ?
Re: The Temptress
#148 Post by LPGC » Sat Oct 16, 2021 8:53 pm
I'd need to recap on this thread to remember fully what issues you were having but it reads good that you've identified engine noise and fixed it by adjusting timing chain tension.
Start with the idle bypass/adjustment. If that is too far open it will allow unmetered gas to flow into the plenum even if there isn't a reducer fault.
Re: The Temptress
#149 Post by Gilbertd » Sat Oct 16, 2021 9:01 pm
+1 on idle bypass, screw it fully in and try it like that.
robertXX
Re: The Temptress
#150 Post by robertXX » Sun Oct 17, 2021 8:27 am
ill check it today , buy i am pretty certain the idle screw is shut .
