2002 l322 coolant hose probs
johnny2768
Re: 2002 l322 coolant hose probs
#41 Post by johnny2768 » Wed Jul 29, 2020 6:04 pm
i noticed that last night it was the black and white wiring on the prins fitting guide saying that was a hall sensor,but it also said you can select a hall guage or a standard 0to 95 via the dash guage pressing once for standard guage and twice for hall on initial start up so should i just get a 0-95 one?
#42 Post by Gilbertd » Wed Jul 29, 2020 7:03 pm
As it's cheaper, why not? That's probably what you have now rather than the Hall Effect one but as the resistance didn't change when you moved the needle, it's broke.
johnny2768
#43 Post by johnny2768 » Wed Jul 29, 2020 7:19 pm
ideal i will do that shortly and let you all know how it goes thanks again
johnny2768
#44 Post by johnny2768 » Sat Aug 01, 2020 5:37 pm
well i got my new tank guage for a levello tank and it didnt even register but what i did notice i bought a 0-90 should be 0-95 would that make a difference
#45 Post by Brian_H » Sat Aug 01, 2020 5:49 pm
It might indicate sooner that its lower than the 0-95 if you didn't change settings, but no not really. You do need to get the software to actually show the right type of gauge though, and may need to play with calibration. If your happy it now works (we know you have a new gauge now, but that doesn't prove the wiring, you could do that with a multimeter with the wires at the other end of the car and the same test as before) it may be a case of getting someone with the proper software to sort it out for you. Unless you can get whatever you have to work properly.
johnny2768
#46 Post by johnny2768 » Sat Aug 01, 2020 6:10 pm
but should my tank guage show something its showing empty when im full or is that a hall sensor
#47 Post by Brian_H » Sat Aug 01, 2020 6:19 pm
The new gauge should show the contents of the tank if your talking about the pointer on the new gauge. If it doesn't (the magnetic pickup should set itself when you put it in place, might need to turn it around a bit to get it to pickup on a 4 hole tank) then it would sound like you have a problem with the float side. Though I'd think that unlikely its not impossible. Could be that its stuck at the empty position.
Does the gauge move if you unscrew it, move it to full with the screwdriver on back technique, then put it back on the tank?
johnny2768
#48 Post by johnny2768 » Sat Aug 01, 2020 7:07 pm
gave it a wiggle about and it shot up to full just need to use some gas now and see how it goes thanks again
johnny2768
#49 Post by johnny2768 » Fri Aug 07, 2020 6:50 pm
finally got out in thecar today and ihave a working dash guage and tank guage i just took the fuse out for the gas like it tells you to do online,pressed the fuel guage button for 5 secs till it beeps then press once and it now shows half a tank so a big thank you for all your input and especially your patience
