looking for Gasitaly F1 PC Interface USB-CAN
hi i looking for gasitaly f1 pc interface usb-can. anyone can help me to find it. thank you.
- ecu gasitaly f1
- 20120718_120926.jpg (186.95 KiB) Viewed 2506 times
- connector for usb interface
- 20120718_120849.jpg (158.72 KiB) Viewed 2506 times
Re: looking for Gasitaly F1 PC Interface USB-CAN
Looks like the standard aeb oval interface, you may need to swap the two centre pins about, they are the data stream, the outer pins are 12v and earth. Have you got the software ?
yes i got the software from official website gasitaly (gasitaly V7.9). now i want the cable only.
Make one. You'll have to work out which pin is which but once you've identified the + and ground, the other 2 are a 50/50 chance.
- RS232.jpg (45.89 KiB) Viewed 2488 times
Nice diagram type rs232. anyone can provide usb type or ready made to buy.
Try WTV (www.wtv-uk.co.uk). They do numerous different interfaces, which are all basically the same except for the connecting plug, in serial and USB versions. As Tubbs has pointed out the connector looks the same as the standard AEB connector so get one of those. At worst you will need to swap the pins around.
