USB interface problem OMVL Dream
Re: USB interface problem OMVL Dream
#61 Post by Brian_H » Tue Jun 02, 2020 9:51 pm
Good stuff, best of luck, post back if your still having issues!
#62 Post by LPGC » Tue Jun 02, 2020 11:54 pm
Very good!
I couldn't find my previous notes on AEB2568 pinout, so last week when I had a spare half hour I manually checked a loom and noted the pinout..
From my notes (my notes lol.. so they probably won't make quite as much sense to other people but I'll understand perfectly if/when I read them again)....
Pinout taken from a late spec King AEB2568 loom (2015ish) with OBD connection wires.
Pins are numbered 1>56.
Pins 1>28 on one row (row A), pins 29>56 on the other row (row B). Row A and row B numbers run in the same direction, thus pin 29 is adjacent to pin 1 and pin 56 is adjacent to pin 28. There is a space between 14 and 15 and there is a space between 42 and 43, I have termed A *tbc below*
When looking at the connector from with the purple slide block at the right, row A is numbered 1 bottom left to 29 bottom right.
When looking at the connector from the front with the slide block at the right, row B is numbered from 1 top left to 29 top right.
When looking at the connector from the rear (wiring side) with the slide block at the right, row A is numbered 1 top left to 28 top right.
When looking at the connector from the rear (wiring side) with the slide block at the right, row B is numbered 29 bottom left to 56 bottom right.
When looking at the ECU face up (label on top) with connector block pointing toward you and slide block at the right, numbering is 1>28 top left to top right, 29>56 bottom left to bottom right.
There is a column space between 14 and 15 and a column space between 42 and 43. I have termed A1>14 block A1, A15>28 block A2, B29>42 block B1, B43>56 block B2. A1 & B1 are together (just different rows) and A2 & B2 are together (just different rows).
Pins
Block A1
01 channel 1 petrol injector cut loom output / bank1 (blue)
02 channel 2 petrol injector cut loom input / bank1 (red black stripe)
03 channel 2 petrol injector cut loom output / bank1 (red)
04 channel 3 petrol injector cut loom input / bank1 (green black stripe)
05 channel 3 petrol injector cut loom output / bank1 (green)
06 channel 4 petrol injector cut loom input / bank1 (yellow black stripe)
07 channel 4 petrol injector cut loom output / bank1 (yellow)
08 channel 5 petrol injector cut loom input / bank2 (blue black stripe)
09 channel 5 petrol injector cut loom output / bank2 (blue)
10 channel 6 petrol injector cut loom input / bank2 (red black stripe)
11 channel 6 petrol injector cut loom output / bank2 (red)
12 channel 7 petrol injector cut loom input / bank2 (green black stripe)
13 channel 7 petrol injector cut loom output / bank2 (green)
14 channel 8 petrol injector cut loom input / bank2 (yellow black stripe)
Block A2
15 Main power +12v (thick red black stripe) Note loom joins to 43
16 unused
17 unused
18 Tank solenoid output (thick blue)
19 Reducer solenoid output (thick blue white stripe)
20 unused
21 Common for injectors on bank 1 channels 1>4 (black)
22 Common (earth) for switch, temp sensors and map sensor.
23 channel 5 gas injector pulsing output (brown)
24 channel 6 gas injector pulsing output (red)
25 channel 7 gas injector pulsing output (orange)
26 channel 8 gas injector pulsing output (yellow)
27 channel 1 gas injector pulsing output (brown)
28 channel 2 gas injector pulsing output (red)
Block B1
29 channel 1 petrol injector cut loom input / bank1 (blue black stripe)
30 lambda 2 input (purple black stripe)
31 lambda 2 emulation output (grey black stripe)
32 lambda 1 input (purple)
33 lambda 2 emulation output (grey)
34 level sender (green)
35 level sender (white)
36 gas temp sensor (orange black stripe)
37 reducer temp sensor (orange)
38 map sensor (red yellow stripe)
39 map sensor (orange black stripe)
40 rpm wire (brown but in tight black sheath)
41 ignition on wire (red white stripe in sheath with bank 1 petrol injector cut wires)
42 channel 8 petrol injector cut loom output / bank2 (yellow)
Block B2
43 Main power +12v (thick red black stripe) Note loom joins to 15
44 interface (pink)
45 interface (pink black stripe)
46 common power feed to map senor and switch, no direct connection to main loom earth.
47 switch (brown)
48 switch (blue)
49 common feed to gas injectors on bank 2
50 Main earth. (thick black) Note loom connects to solenoid earth wires
51 OBD (yellow grey stripe)
52 OBD (green)
53 unused
54 OBD (yellow green stripe)
55 channel 3 gas injector pulsing output (orange)
56 channel 4 gas injector pulsing output (yellow)
