Zavoli Alisei momentarily cutting out / switcing to petrol on moderate acceleraton
Re: Zavoli Alisei momentarily cutting out / switcing to petrol on moderate acceleraton
#21 Post by LPGC » Sun Jun 21, 2020 9:13 pm
The weak setting may have improved things.
By hiccup do you mean interface connection problems, rpm detection problems and/or drive-ability problems? Connection problems and rpm detection problems can seem to come and go on these systems and rpm detection problems can cause drive-ability problems.
It may be a bit early to feel relieved of hiccups, hopefully not!
Misfires can also cause hiccups. If the mixture is too rich you're likely to get a hiccup and by entering a lower reference pressure in software you'll have effectively leaned the mixture a little. A leaner mixture also implies a lower ginj, connection issues generally occur at high ginj's.
Pleased to read your promising results.
danci1973
#22 Post by danci1973 » Sun Jun 21, 2020 9:17 pm
Day 2 of 'no hiccop'. I did some casual driving over the day and then a 'dedicated test drive' of about 100 kilometers...
I'm not popping the champagne just yet, but I will put one in the cooler. :D
#23 Post by LPGC » Sun Jun 21, 2020 9:29 pm
Very good!
Did you make any changes to extra injection filtering etc?
danci1973
#24 Post by danci1973 » Sun Jun 21, 2020 10:02 pm
I meant the initial problem of LPG momentarily switching off / to petrol. The laptop to ECU connetion did occur once (I think).
I will try to improve the map a little, but will need a helping hand for that, so that's coming some time in the future.
Very good!
Compared to the initial setup (from the installer), I probably did - I did experiment with that setting, but I didn't record every single change I made. I believe the slider was initially fully to the left whereas I've set it 3 places to the right.
But if you meant from my last report on Thursday - no, the only change I made was the 'Type of revolution signal' -> 'Weak' (and gas pressure from 1.5 to 1.4 bar).
danci1973
#25 Post by danci1973 » Fri Jun 26, 2020 9:28 pm
Well, it's been a couple of days and I've put about 1500 km on the car without any (LPG related) issue whatsoever. I guess I'm ready to call it 'a success' and pop that proverbial champagne... :)
Thank you very much for your help, Simon, it's been very valuable.
#26 Post by LPGC » Mon Jun 29, 2020 8:03 am
You're welcome
