hi all,
i have big problem when setting my gasitaly f1 cng to my 4g92 engine.
first situation on petrol i setting 9 degree btdc my engine give me a good performance.
2nd situation on cng i need to set 12 degree btdc for good performance. but my engine knocking when on petrol.
my setting cng 700 rpm n below running petrol, after 4200rpm run petrol for overtaking.
now i setting 11 degree on cng engine running good but still have problem when have cool weather, on petrol knocking when high rpm.
any suggestion to fix this problem
thanks
advance on cng and retard on petrol
Re: advance on cng and retard on petrol
thanks for that info. but i already ask their technical asst and result no timing advance processors suitable for my engineGilbertd wrote:http://www.aeb.it/products/timing-advance-processors
any other solution
regard
- Installer
How have you been adjusting the timing?
adjust the distributor refer on timing light to set btdc. just a normal method to basic timing on efi systemclassicswede wrote:How have you been adjusting the timing?
- Installer
If it has a distributor then it should be possible to use a advance processor.
http://www.autogasitalia.it/db/prodotto ... ng&id=1778
how much cost and where i can by this timing advance processor..
