BMW745 Valvetronic converted by LPGC
#1 Post by LPGC » Fri Nov 04, 2016 6:19 pm
I just converted a BMW745 Valvetronic, engine bay pics below.
I usually fit AEB on V8 installs but for this model I chose KME Nevo, with single MJ injectors and KME Gold reducer.
For those that don't know (which won't be many on this forum), Valvetronic engines are capable of running in a mode which doesn't use the throttle to restrict airflow into the engine's cylinders in the usual way. When running in Valvetronic mode, the engine valves control flow of air into the cylinders instead of the throttle by means of some clever engineering. They still have a throttle and are capable of running in conventional throttled mode but much of the time they run in Valvetronic mode (and seemingly sometimes part Valvetronic / part throttled mode).
Petrol pressure on these engines isn't relative to engine vacuum (as is the case with most engines), petrol pressure is instead constant above atmospheric pressure and in the case of this 745 model that pressure is around 50psi. So, petrol pressure relative to manifold pressure will be at 50psi when the engine is running in fully Valvetronic mode or running flat out in throttled mode, because in these situations the manifold pressure is almost the same as atmospheric pressure (the throttle is fully open all the time in fully Valvetronic mode) but when the engine is not running in fully Valvetronic mode (when the throttle is used to restrict airflow into the inlet manifold) and the engine is running at part throttle the manifold pressure is below atmospheric pressure, so petrol pressure relative to manifold pressure increases. I.e. If the engine is idling in Valvetronic mode, manifold pressure will be very near atmospheric pressure (1 bar) so relative petrol pressure (to manifold pressure) will be 50psi but if the engine is ldling in normal throttled mode then manifold pressure might only be 0.3 bar. Since atmospheric pressure (1 bar) is 15.4psi, manifold pressure in psi at 0.3 bar is only 4.62psi.. So relative petrol pressure under these conditions would rise to 50+15-4.62psi = 60.38psi, which is more than a 20% increase in fuel pressure. This means that in order to correctly fuel the engine the petrol ECU must pulse petrol injectors for a different length of time depending on which mode it is operating under... If the petrol ECU needed to pulse petrol injectors for, say, 4ms to provide the correct amount of fuel for the engine to idle with correct mixture under Valvetronic conditions, but it then continued to pulse petrol injectors for 4ms when the engine reverted to throttled mode, then the air/fuel mixture would become around 20% too rich - so the petrol ECU knows which mode it is operating under and compensates petrol injector pulse time accordingly... that 4ms pinj would become around 3.2ms with manifold pressure of 0.3bar.
Regards LPG conversion the above presents a bit of an issue that must be properly addressed if the car is to be fuelled correctly in more than one mode of engine operation. Modern day vehicles, certainly including this BMW745, must be converted with an LPG fuel system which works as a slave to the (master) petrol fuel system because the petrol ECU expects to have direct control over fuelling and will generate all types of error codes if in any way it detects it does not have very precise direct control over fuelling (which it interprets as a problem with the engine itself or with one of it's engine sensors). If LPG calibration is only correct for Valvetronic mode and the vehicle switches to another mode during driving on LPG (which they occasionally do anyway, sometimes seemingly just to confirm the throttle works), then the vehicle may generate error codes for incorrect mixture. If such codes are generated, Valvetronic engine ECUs can be reluctant to switch back to Valvetronic mode because throttled mode is also the failsafe mode (the Valvetronic method of operation is much more complicated than throttled mode requiring very precise control over the 32 engine valves, first thing that happens with a problem is the petrol ECU switches back to much simpler throttled mode). It follows that a latched mal-running / catch22 situation can therefore occur, i.e. if the engine doesn't switch back to Valvetronic mode, then while-ever the engine runs (especially at low loads) on LPG the mixture will never be correct, and since the mixture isn't seen to be correct in throttled mode this becomes a constant problem because the engine will not switch back to Valvetronic mode, and so the incorrect mixture continues, the error mode continues and the error condition becomes constant until the engine is restarted (and quickly switches to Valvetronic mode before errors are noted in throttled mode). The LPG slave ECU's only input from the petrol ECU regards fuelling is the petrol injectors pulse duration (this is 'would be' pulse duration, as of course petrol injector signals are disconnected from petrol injectors when running on LPG) and this is where the problem begins. Above we can see that 4ms of petrol injection pulse duration in Valvetronic mode equates to the same flow of fuel to the engine as 3.2ms in throttled mode but 4ms of petrol injection in throttled mode is a very much greater does of fuel than 3.2ms in Valvetronic mode (quick estimate 40% difference in fuel dosage here!), while LPG ECU's don't normally know, care or attempt to address whether the engine is running in Valvetronic mode or throttled mode.
If it were possible to run LPG vapour pressure at 50psi relative to atmosphere (the same as petrol pressure) then there wouldn't be a problem, because LPG pressure relative to manifold pressure would be the same as petrol pressure relative to manifold pressure under any engine mode. But we cannot do that for several reasons.. LPG (even neat propane variant) would condense back into a liquid in freezing weather (well, freezing vapour pipe and injector) conditions, while even in warmer conditions LPG injectors wouldn't work properly at such a high pressure.
Some installers set a high changeover temperature and hope the engine will run only in only one of it's modes (usually Valvetronic) following the changeover to LPG, thus disregarding correct fuelling in the event the engine at some point reverts to another mode... and it will at some point revert to another mode... because A. Or why else would BMW bother to even fit a throttle? B. The petrol ECU will occasionally check that the electronic throttle still works properly as part of it's usual system checks, C. These engines tend to have a lot of phantom pending OBD codes for such as cam sensor issues (enough for the engine to switch to throttled mode in some circumstances), D. With a cold engine the ECU may dictate throttled mode in some circumstances (and the LPG system may switch to LPG mode before the engine is warmed enough to switch to 100% Valvetronic mode, E. Following any clearing of OBD codes or resetting of fuel trims the petrol ECU will want to re-learn and confirm correct running/fuelling in throttled mode just as much as re-learning how to fuel the engine correctly in Valvetronic mode.
Given the 20% discrepancy of fuelling between modes, some installers try to set calibration on middle ground between modes, so with continued luck fuel trims might bend negative 10% in throttled mode and positive 10% in Valvetronic mode if they connected the LPG reducer and pressure sensor to manifold vacuum. This in itself can lead to continued switching between modes as the petrol ECU attempts to check differences between fuelling in different modes are as should be expected (and finds the difference is not as expected, which rings alarm bells as far as the petrol ECU is concerned, thus leading to further checks. A Valvetronic ECU running such checks will often hold engine idle speed at around 1100rpm as it checks expected necessary differences in fuelling are as expected, not only for low idle speed (say 600rpm) but over a wider range of idle speeds too (the higher idle speed means greater manifold vacuum when running in throttled mode than there would be at low idle speed, thus allowing comparison where the difference in petrol injection time between engine modes should be greater than at low idle speed, and info collated at 1100rpm serves as a second set of reference figures which can be compared to 600rpm figures). The '1100rpm syndrome' could be considered as a point F in the above paragraph.
Old advice from one system supplier (which worked OK particularly on early big engine models in the Valvetronic line up) was to not connect LPG reducer or pressure sensor to manifold vacuum and set LPG calibration with a 'flat map'. This has the effect of increasing actual relative LPG pressure while the LPG ecu does not see or account for the increased pressure (by decreasing gas injector duration as pressure rises), so the petrol ECU decreases it's petrol injector duration in throttled mode (compared to Valvetronic mode) but the LPG system working with greater effective pressure which it hasn't accounted for therefore in a way compensates by default by flowing more gas... This works up to a point but can be system/component specific, because factors such as injector response times and abilities of working properly at high pressures (e.g. 1.7 bar relative to atmosphere becomes 2.4 bar relative to a manifold at 0.3bar) play there part in helping to compensate for that 20% difference in fuelling. If you swapped any of the components, perhaps for what would usually be considered better spec components, then the 20% that was achieved using the original components might become say 5% or 40%... I still remember Nick at FES saying something like don't connect vacuum pipes to reducer or pressure sensor, with OMVL metal bodied injectors and OMVL HP reducer set a flat map of 176 and it should work OK - and it did work, kind of, most of the time. It may not work with a different pressure or different injectors or different ECU (that assumed a different injector response time to the OMVL ECU even for the same model/spec injectors). It did not work nearly so well on smaller engine'd Valvetronic models in the line-up such as the 3.5V8, this will be because some of the dynamics discussed here (injector response etc) will have a different effect on fuelling across the load range on early 3.5Valvetronics compared to the early 4.5Valvetronics.
A few reasons led to my choosing the Nevo ECU for the Valvetronic, not least my experiences of using 2 x 6 cylinder Nevo ECU's on the 6L V12 twin turbo Merc I fairly recently converted http://www.lpgforum.co.uk/viewtopic.php?f=27&t=14115. On the Merc I overcame an issue with incorrect fuelling leading to drive-ability problems when turbo boost came in by realising the problem was due to petrol pressure (of 5bar) being relative to atmospheric pressure, which would be 6 bar if the manifold could ever reach full vacuum and became only 4 bar when the manifold reached 2bar (1bar atmosphere plus 1 bar of turbo boost pressure). The difference between idle manifold pressure and full boost pressure meant petrol pressure relative to manifold pressure fluctuated by 40odd%, so, say, 8ms of pinj with manifold pressure at atmosphere would represent a very different (and greater) amount of fuel dose compared to 8ms of fuel dose with the manifold pressure boosted by the turbos... Such discrepancy usually only occurred for a very short time on this vehicle because 8ms of Pinj would imply the throttle/rpms to be at a level where the turbos would soon bring the manifold up to boosted levels but even during that short period the fuelling error was enough to cause a problem. The Nevo ECU allows fuelling on gas to be compensated according to manifold pressure and the range of manifold pressures covered can be defined - on the Merc that range needed to address absolute manifold pressures between 0.2 bar and around 2 bar, where as on a Valvetronic the range would only need to cover 0.2bar to 1bar. Addressing the problems on the Merc by dialling in manifold pressure compensation led to thinking of the implications for Valvetronics and I decided at that point that I'd fit a Nevo on the next Valvetronic I converted. On the Merc not connecting the reducer pressure reference to manifold pressure would not be plausible, because with reducer pressure set to even a relatively high pressure such as e.g. 2 bar the effective LPG pressure range relative to manifold pressure would have fluctuated between 1 bar (under boost conditions) and 2.8 bar during engine over-run, way too much of a fluctuation for injectors to work above minimum duration they could accurately meter fuel at at one end of the scale and way too little pressure for same injectors to flow enough fuel under boost conditions. With reducer and sensor connected to manifold the compensation range for ginj duration had to cover a range of around 40%, much more than would be necessary for a Valvetronic and it worked well even in this case so I knew it would work well on the Valvetronic. Other ECU's feature compensation for manifold vacuum (and other unusual things to compensate for) similarly to Nevo but in the case of other ECUs I find such facilities can sometimes be gimmicky, don't work as they should and don't allow the user to set/see the settings that are being applied, i.e. a graph on which you can adjust points to any position you like and set as many points as you like but which has no scales on the axis does not allow the user to set a specific amount of compensation from the outset.
For both this Valvetronic and the Merc I used a spreadsheet to calculate the compensation figures that I'd need to apply over the full range of manifold pressures, pictured below.
This is how I entered the compensation figures in Nevo for the Valvetronic
Pic of map functioning in throttled mode. Clear to see it's in throttled mode, manifold pressure of 0.37 bar is a give-away in itself. Note how for pinj of 3.3ms, ginj is 5.1ms (granted with approx +9% of pressure and temp correction). The reason ginj is as high as 5.1 is for the most part due to the +17% manifold pressure compensation that I have dialled in. There are two +17% figures, each relevant to one bank of engine cylinders.
Pic of map functioning in Valvetronic mode. Clear to see it's in Valvetronic mode because manifold pressure being 0.96bar while pinj is only 3.3ms. Note how for pinj of 3.3ms, ginj is 3.4ms (granted with approx -10% of pressure and temp correction).
Valvetronic mode makes for quicker throttle response but also makes for more efficient engine running. This partly accounts for pinjs being the same in the above couple of screenshots. Since relative petrol pressure is around 20% lower at idle in Valvetronic mode compared to throttled mode but pinjs are the same, this demonstrates that the engine is idling 20% more efficiently / using 20% less fuel to idle in Valvetronic mode compared to throttled mode. Of course, the efficiency gains from Valvetronic become less pronounced compared to throttled mode as engine load increases because as engine load increases in throttled mode, manifold pressure increases anyway. Maintaining vacuum in the inlet manfiold implies a pumping loss, which in part refers to the work the engine has to do just to suck air into it's own cylinders.
If we take the 5.1 figure and take away 10% (approx total pressure and temp correction) we are still left with 4.59ms, if we take the 3.4ms and add 10% we are left with 3.74ms. The difference between ginj's of 3.74ms and 4.59ms highlights the fueling error that would have been present when the engine switched modes between Valvetronic and throttled modes if the manifold pressure versus fuel pressure issue had not been properly addressed and, as I'd expect, that difference represents a fueling error of around 22%! But since this has been properly addressed on this conversion, fuelling is correct all the time regardless of the engine switching modes of operation and the engine can switch seamlessly between modes while continuing to run properly and smoothly all the time while with little change in fuel trims between modes or between petrol/LPG operation.
Also note that if the LPG system was calibrated in the usual way (and while the engine was running in Valvetronic mode), then the usual assumption would be that the multiplier would be too high (regards ginj of 5.1 versus pinj of 3.3), so an installer might increase pressure and/or nozzle size to bring those figures closer together. But, if they did that, then even if the pressure compensation I've described was later somehow properly configured the vehicle still wouldn't run properly on LPG in throttled mode, because now the gas injectors would need to pulse below the minimum duration that even the fastest gas injectors could accurately work... This implies that some installers conversions that work OK in Valvetronic mode but haven't addressed running in throttled mode would need at least a change in pressure, perhaps a change in nozzle size too, perhaps a change in ECU and more thorough consideration of the issues and how to overcome them in order for the install to work properly across all modes of engine operation. This would be more likely to be the case if an installer hadn't fitted injectors that were as quick in response as the injectors I fitted, in which case there might have to be some trade off between the engine idling propelry in all modes on LPG and the LPG system being able to flow enough gas within available injection window (duty cycle of LPG injectors) for the engine to be able to receive rich enough mixture flat out at high rpm. Of course in this situation (where you can have one or the other) the installer should opt to set the system so that the engine is capable of performing properly at idle and low loads rather than flat out at high rpms, i.e. implying petrol addition or a switch back to petrol completely at combinations of high rpm and high load.
Unless the installer intention is to attempt to approximate the 'old advice' type scenario I described above in order to make for a system which delivers correct fuelling under all modes of operation, then they would be well advised to fit very fast response injectors but real world injector response can be very different to manufacturer/supplier/forum users claims. It might prove difficult for someone without very relevant experience to steer a path through hype about injectors or to approximate a setup that makes for correct fueling in all engine modes on Valvetronics in a similar way to the 'old advice' scenario (which it seems worked luckily more due to aspects of components rather than being a fully considered solution).
A few pics of the BMW745 Valvetronic I just converted engine bay.
Work in progress
Related thread http://www.lpgforum.co.uk/viewtopic.php?f=32&t=13790
Re: BMW745 Valvetronic converted by LPGC
#2 Post by LPGC » Wed Dec 07, 2016 9:40 pm
Though I didn't mention it in the post above, it occurred to me (even while I was working on the above car) that I could achieve the same type of manifold pressure correction with a wide range of other LPG ECU's... even ECU's that don't feature vacuum correction.
To achieve this with other ECUs (where possible) it is necessary to involve a bit of electronics trickery and a bit of a fudge with ECU settings, but where possible the manifold pressure correction should work just as well as with the Nevo ECU.
I now offer the service implied above, so if anyone has an LPG converted Valvetronic BMW that has any sort of issue this may be the fix. Of course I would check other aspects of your system were OK and advise accordingly before starting the modification.
#3 Post by LPGC » Tue Oct 09, 2018 9:23 pm
Converted quite a few BMW 745's since (and before) I converted the one on this thread.
The most recent was a couple of months ago but I've had another BMW745 dropped off for conversion this evening, nicely timed as I was just finishing conversion of another car this evening. Just a test drive (with diagnostic gear hooked up) of the car I've finished converting this evening in the morning and then straight to work converting the Beemer.
A 'semi Valvetronic' BMW 318 is coming in for conversion on Monday. I left the rear end of next week free of conversions (though I could have filled next week with conversions many times over) to attend to customers from up and down the country who've been waiting for my nod to bring their vehicles in (that were converted to LPG elsewhere) for their LPG systems sorting. So just the one conversion next week but around 8 repairs customers.
57jam89
#4 Post by 57jam89 » Fri Oct 12, 2018 7:21 am
Great write up simon on how it all works, nice one.
#5 Post by LPGC » Fri Oct 12, 2018 11:17 pm
57jam89 wrote:Great write up simon on how it all works, nice one.
Thanks Simon.
All done on this latest one except for calibration and putting the engine bay trim covers back on.
Was working on this latest one until 9pm tonight. Set off to go and fill the tank with LPG, these usually drive like on rails in normal driving (I think more so than just about any other model of car really... to a point) but this one didn't quite strike me with the handling as they usually do and after about a mile I reckoned there must be something wrong at the back end. Stopped and the found the back offside tyre was flat, it's a run-flat but still didn't want to drive further so slowly returned to base and inflated the tyre. Seems to be holding pressure but I'm going to get up early, see if it's kept pressure, have another look around the tyre, maybe take it to my mate's tyre place for them to check it out. Bit peeved because I expected to have it calibrated tonight!
#6 Post by LPGC » Sun Oct 14, 2018 11:59 pm
Got that latest BMW745 Valvetronic all done and dusted yesterday and I'm very happy with the results.
The tyre did hold pressure from Fri night (day of my last post above) to Saturday and I was able to take it for a blast to calibrate it etc. All good.
Owner collected it today, coms have all been via emails and have been slow, when he came to collect it I of course mentioned that the tyre went down when I went for fuel and to calibrate the LPG system. He said 'Ahh yes they do go flat, it's because the coating on the alloys is coming off so they leak on the rim... I just drive around on them flat because they're run flats!'.
The BMW318 I mentioned was coming for conversion on Monday has been postponed because it's having a new oil pump fitted, we've arranged a later date for that. But it didn't matter to me much due to 'could have filled next week several times over'. I've now probably overdone it for next week by taking on 2 people carrier full conversion jobs and some repairs customers. Had two cars dropped of for conversion today since I had to be at work anyway for the 745 to be collected.
57jam89
#7 Post by 57jam89 » Mon Oct 15, 2018 8:20 am
Unbelievable.
Good to hear your still busy!
#8 Post by LPGC » Mon Oct 15, 2018 10:32 pm
My thoughts too! It seemed to be handling dodgy on the way to the garage on the A1. Pulled onto the A1 garage forecourt but found it closed for repairs. Intended on heading South on the A1 to Morrisons forecourt near Doncaster but on the road approaching the flyover to turn around on the A1 at Wentbridge I gave it a bit of throttle and the back end was everywhere... I wouldn't want to drive it like that!
Yep,very busy.
topsie
#9 Post by topsie » Mon Feb 18, 2019 2:07 pm
I'm looking at installing an LPG system on a 745 Valvetronic so doing some research - fantastic insight into a problem I would not of foreseen otherwise.
Given that the engine only runs for a small proportion of time in throttled mode, would a more simple solution (assuming the software allows) be to revert to petrol when manifold pressure is ~0.3 (ie in throttled mode)
What would be the downside of such a setup?
Nick
#10 Post by LPGC » Tue Feb 19, 2019 10:29 am
Nick
If you calibrated only for full Valvetronic mode then fuelling in throttled mode would be off whenever manifold pressure was different from atmospheric pressure, while obviously in throttled mode manifold pressure can fluctuate anywhere between 0.2odd bar on over-run to atmospheric pressure at full engine load... So there wouldn't be a magic manifold pressure at which to set switching back to petrol but you may be thinking along the0.3 correct lines in that fuelling would be less accurate as manifold pressure gets lower (with increasing vacuum). However, Valvetronics have a partial Valvetronic mode, they don't switch straight from throttled to Valvetronic mode or vice-versa (and we'd definitely notice a 'lump' in engine smoothness at that point if they did), there are also partial Valvetronic modes where the throttle and Valvetronic system are both active, i.e to switch from throttled mode to Valvetronic mode there isn't a sudden switch from one to the other there is a transition period where manifold pressure gradually increases (throttle opening so increasing manifold pressure) while at the same time Valvetronic gradually decreases engine valve opening. In fact there seems to be an in-between mode where manifold pressure hangs at around 0.5 bar for part load situations that wouldn't demand more engine power than the engine could make with 0.5bar manifold pressure (of course if the driver demands more power the throttle valve will open to allow a higher manifold pressure even in this mode). The inbetween mode is more apparent on BMW's 4 cylinder Valvetronics like the 318 than on it's V8s.
So the problems with your ~0.3bar switching scenario are (besides it being a fudge that cannot fuel the engine over much of it's range of operation so simply gives up and switches back to petrol!) - To prevent even slightly dodgy fuelling you'd want it to switch closer to 0.9bar. Anytime it was running with a lower manifold pressure than the switching map you'd be running on more expensive petrol instead of LPG, they will occasionally run in throttled mode anyway... the electronic throttle is an important fallback in case of any problems (such as with the VT system but also in case other parts of the engine management system go down) so the car checks it's still working properly by using it. You might need to hack some firmware / settings files or come up with an add-on electronic hack to set a system to switch back to petrol below such a high manifold pressure as say 0.8 bar (ECU designers didn't intend switching for manifold pressure to be used for such purpose, more likely to be an option to switch back to petrol above a certain manifold pressure than below a certain manifold pressure except for over-run and long cut-off type options which might allow setting to switch back to petrol below maybe 0.4 bar etc).
topsie
#11 Post by topsie » Tue Feb 19, 2019 11:01 am
Thanks for the detailed reply Simon,
It would seem your method of corrections for any given manifold pressure is the only real solution for gas over all ranges of operation - especially given the different running conditions associated with valvetronic!
Nick
#12 Post by LPGC » Sun Apr 14, 2019 11:20 am
Late reply but seems I forgot to say thanks for that Nick.
Thanks,
#13 Post by LPGC » Thu Jun 17, 2021 3:45 pm
I recently pointed my son to this thread because he's having problems with his none LPG-converted BMW325 with the direct injection N53 engine.
His problem isn't directly related to the subject of this thread, his engine seems to be suffering the common N63 crankcase breather problem - The PCV is sucking too much intake air through the crankcase leading to whistling noises, poor idle and system too lean codes. The fix for that seems to be to replace the whole cam cover on this engine because the PCV is built into it and irreplaceable without changing the full cam cover. I explained that the problem could have existed for a long time but symptoms only recently developed if for most of that time the engine was running in Valvetronic mode during which it doesn't have any manifold vacuum (and therefore wouldn't make a vacuum in the crankcase either).
While visiting this subject again I thought I'd update it. I've just converted a Toyota Avensis with the 4 cylinder 1.8 litre Valvematic (similar to BMW's Valvetronic system) engine and have dialled in manifold pressure compensation on this one just as I would for any engine with constant fuel pressure and Valvetronic type intake system... In fact I dial in manifold pressure compensation on any engine that runs fuel pressure that isn't relative to manifold pressure - but the positive effects on correct LPG calibration from dialling in the manifold pressure correction are most noticeable on engines with Valvetronic type intake systems because it is on those engines that the amount of fuel delivered from X ms of petrol injection pulse may be most different from the same X ms of petrol injection pulse for changing engine conditions (the switch between throttle and Valvetronic type modes).. But some of the same effects are noticeable even on engines without Valvetronic like features if the engine runs none manifold relative petrol pressure.
In the past the only way I could force a Valvetronic engine to switch to throttled mode was to cause some sort of OBD error that would see the ECU default to throttled mode.. ECU's for engines with Valvetronic type systems will usually switch to throttled mode (instead of Valvetronic mode) in 'limp home mode' or if relevant parts of IM readiness haven't been completed, so in the past I intentionally caused a problem for the ECU that would force switchback to throttled mode. But to switch back to Valvetronic mode involved a wait until IM readiness had completed. I suspected that a new scan tool would allow force switching between Valvetronic mode / throttled mode at will, and today I put that to the test on the Toyota. It does allow switching intake modes on the Toyota and I believe it will allow switching intake modes on the BMW. Later today I'll be visiting my son and we'll see if when I force the engine to run in Valvetronic mode the crankcase vacuum and whistling noises decrease.
The ability to switch intake modes at will on the Toyota has so far helped further prove that my calculations for fuelling compensation are correct, it previously took a long time between forcing modes and re-checking calibration was correct in each mode but the ability to switch modes at will has speeded up these checks.
Pics of forcing intake mode on the Toyota with Valvematic intake system. On the Toyota 'activate the Valvematic after warmup' really means force switch to Valvematic mode (and 'activate the Valvematic before warmup' really means force switch to throttled mode).
Stft's are quite high in the pic below but they are the same as on petrol.
Edit - Nearly forgot to mention that in more recent firmware and software updates for Nevo there has been the ability to dial in manifold pressure compensation in it's own right (it's own setting / table) without needing to use the RPM correction re-configured to compensate for manifold pressure. KME took my advice on that. Also in more recent software / firmware updates the Valvetronic option tickbox now turns on pseudo compensation for manifold pressure but it does it in an incorrect way by changing the gas pressure it acknowledges and is designed to be used when reducer pressure isn't reference to manifold pressure. I have already explained (in my opening post on this thread) why not referencing reducer pressure to manifold pressure is a bad idea (brief example - if you set reducer pressure at 1.2 bar above atmospheric pressure then relative pressure will be 1.9 bar when the manifold is at 0.3 bar... With correct nozzle size the engine might need 1.2 bar of pressure for enough fuel flow capacity at high loads but the 1.9 bar in throttled mode at low loads might be excessive and force injectors to try to deliver fuel at a pulse duration below which they become linear and can accurately measure fuel dosage...). Not referencing gas pressure to manifold pressure effectively limits the range of engine loads for which the LPG injectors are appropriate and even if injectors were linear enough to function properly across that entire dynamic range fuelling would still be inaccurate without the compensation for manifold vacuum.
One final point/reminder - It isn't really engine vacuum we are compensating for, it is relative petrol pressure that we are really compensating for... but the gas system cannot directly measure relative petrol above manifold pressure (on most vehicles with Valvetronic type fuel systems even the petrol ECU cannot measure petrol pressure), so instead of measuring relative petrol pressure we can measure manifold pressure and we know that relative petrol pressure increases as manifold pressure decreases... the percentage rise of petrol pressure for changing manifold pressures depends on the petrol pressure, so if have a petrol system that delivers fuel at a constant 4 bar above atmospheric pressure the pressure will be 4 bar at full engine load (0% change), in Valvetronic mode at idle petrol pressure may be 4 bar above manifold pressure at idle loads (0% change), but in throttled mode at low engine loads/idle petrol pressure may be 4.8 bar above manifold pressure when manifold pressure is only 0.2bar (20% increase in petrol pressure above manifold pressure, which the petrol ECU knows to compensate for by decreasing pinj (effectively more fuel pressure so the petrol ECU knows to lower pinj), but the LPG ECU will not compensate for the % difference in petrol pressure and X ms pinj not always being the same as X ms pinj unless it is set up to compensate for it).
