rossko wrote:
SimonHobson wrote:
as far as I can see, a 4-hole vapour tank is the same bit of metal but painted red
No, they are different ; an automotive 4-hole tank has a welded-in downward dipping pick up tube. See halfway down ...
http://www.v8engines.com/Billing_2003a.htm
Even if you mounted the tank upside down, the fillstop float would then be all wrong.
Presumably a red vapour tank has an upward poking tube, never had an opportunity to find out!
Well you learn something every day. I guess that's why they can get away with the price they charge for them.
Quote:
Well known brand Tomasetto vapour multivalve
http://www.tomasetto.com/a_ENG_88_1.html
but electric shutoff. UK availability ????
(suprisingly, 6mm outlet pipe is considered big enough up to, I think, 125cc engine - but this pipe is at full tank pressure, to be fed to the regulator)
Well you've a few bar of pressure behind it, and in a typical caravan you might see long runs of fairly small copper pipe running at low pressure to the appliances. I know that my V8 will run on the vapour that will pass along a few metres of 6mm pipe - it only starts loosing power when the last of the liquid has gone, and then I get at best another mile on rapidly reducing power as I use up the pressurised vapour.
Quote:
I just can't see this working out in legal terms, short of getting the correct kit.
Well the multivalve you show would do the job, all that's required is an adapter to the inlet on a bulkhead mounted regulator - as is now standard on new caravans.
And I checked with a friend who's recently bought a new motorhome - you would not believe the price of them
He has a 28l tank underneath and a switch inside to turn the gas on/off.
I notice the valve above is specced as having an 11W coil on it - so not far short of an amp to run it, though as I said above, it would probably hold open on considerably less.
