 Post subject: Help new System
PostPosted: Fri Apr 27, 2012 3:00 pm
Hi Guys
totally new to the forum so Hello.
I have just brought a Jeep Grand Cherokee 5.7 Hemi on a 2007 plate
I have been quoted by 3 differant companys for differant systems
1/ Stag 300 + system @ £1350
2/ Romano Sytstem @ £1400
3/ Prins Silverline system @ £1600
Can anyone please advise me on what way I should go, and the pluses and minuses of these systems.
Cheers
Yank-tanks
 Post subject: Re: Help new System
PostPosted: Fri Apr 27, 2012 10:39 pm
all systems works fine if its done properly :wink:
LPG INSTALLER,IN DEVON BARNSTAPLE D&B AUTOGAS
peugeot 607 v6 3,0l stag 300 fitted 7 years ago...
done over 80000miles no flash lube
PostPosted: Sat Apr 28, 2012 6:12 am
Stag systems use a Stag ECU and hardware from other manufacturers, usually at the budget end of the market, Romano is Italian and uses components from the one manufacturer as does Prins. As has been said, all will work well if installed properly. I would avoid the Stag as you won't know for certain if the mix and match set of components used are up to the power output of your engine. For the difference in price compared with what you have just paid for the car, personally I'd go for the Prins system. The Silverline is their budget range but is still very good and should last the life of the car.
PostPosted: Sat Apr 28, 2012 11:24 am
Images: 1
witch ever system you choose hake sure they support the hemi as when cruising they switch cylinders of :? :? :?
Facebook Andy Evans Autogas
PostPosted: Sat Apr 28, 2012 7:49 pm
Images: 5
Prins silverline was only available as a 4 cylinder kit[not sure if its available anymore] for the difference in price your better off going for the full VSI.
If your anywhere near essex give me a call and i,ll give you all the info you need .
01702 258286 Woody
PostPosted: Sun May 06, 2012 9:39 am
Hi Guys
I have been speaking to the guys at the Alternative fuel co in barking who are telling me the prins silverline is available for a v8
does anyone know of or has anyone had any dealings with them ?
Users browsing this forum: No registered users and 9 guests
