(1) Once i have removed the purple piece, there will be more room for the injector rail. Currently the gas enters the intake as close as it can to the petrol injectors. I presume it would be beneficial to shorten the 6 hoses coming off the injector rail, marked yellow in the above picture?
(2) To make the install a little more stealthy and less in the way of the air intake, throttle body etc, i may have to lengthen some of the hoses outlined in green. Is it ok to do this? No major problems with lengthening gas lines from the reducer (marked R) and the injectors?
(3) The BRC reducer has 1 coolant inlet, 1 coolant outlet. And 3 additional ports, the top one where the copper pipe connects is 'LPG In'. In the pics below, the bottom port circled orange is LPG out i presume. And what is the port circled yellow, is it an electrical connection? But then it wouldn't have the metal clip. I did manage to get my hands on a comprehensive install manual a while back, but lost it
(4) In the picture below, the green arrow points to an electrical connection. Is the blue arrow pointing to a sensor measuring MAP? The yellow arrow points to a hose/wire which returns to the reducer, is this an electrical wire plugging into the yellow circled port in the above picture?
(5) Lastly with the injector rail now out, I presume its ok to clean out the rail and the individual injector tips with simple carb cleaner? I heard of one fella who cleaned them out with WD40 without any ill effect??
